Originally Posted by tony_fury
There is a panel on the drivers side floor on the left. It has a cover to access all the fuses.
inside the cover once opened, there is a booklet that has all the fuse designations. (Written in multiple languages.)
It designates the Fuse Rows by A, B, C, D, E etc.. Columns are designated 1 thru 10
(There is a fuse puller plastic tool in a spare holder)
When you pull out the fuse, you should see a Z shaped bar inside the plastic fuse. If the Z is broken then the fuse is blown.
there should also be spare fuses stored as well.
15A = 15 amp Blue in color
T
Thanks, tony. I will give this a look in the morning.
