Old 07-25-2012, 11:14 AM   #29
986_inquiry
2006 987
986_inquiry's Avatar
Originally Posted by seningen View Post
Bad Water Pump? or idler pulley
There is a way with the Duramatic to engage the fans -- so you should be able to check that.
Hopefully the no start is that the pulley on the water pump or along the serpentine belt has seized
and its not letting the starter turn over the engine.
Also means that the Alternator is not charging.
should be obvious to eliminate by pulling the front engine panel which is behind the seats.
~10 x 10mm nuts/bolts I believe.
I
mike
It was trying to turn over, didn't sound like anything was seized, but I didn't wanna push it too hard, car dying usually Very Bad Thing, best to tow and let mechanize repair.
Boxster towed little over 1 hour ago, should be in shop by now and I should know something in the next hour
Enterprise just called, they're on their way to my office to pick me up. Hope I don't need the weekly rate
986_inquiry is offline   Reply With Quote
