Old 07-25-2012, 12:03 PM   #11
seningen
seningen's Avatar
Bad Water Pump? or idler pulley
There is a way with the Duramatic to engage the fans -- so you should be able to check that.
Hopefully the no start is that the pulley on the water pump or along the serpentine belt has seized
and its not letting the starter turn over the engine.
Also means that the Alternator is not charging.
should be obvious to eliminate by pulling the front engine panel which is behind the seats.
~10 x 10mm nuts/bolts I believe.
mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
