Old 07-25-2012, 11:46 AM   #11
986_inquiry
2006 987
986_inquiry's Avatar
Sounds like you should upgrade your mechanic & avoid downshifting on the freeway when your car is running hot. Also when your coolant level is low add distilled filtered water as it makes the engine cooler than antifreeze.
Like post said, I was getting off highway. Can't do 20mph in 5th
I added distilled water Tuesday morning
986_inquiry is offline   Reply With Quote
