Old 07-25-2012, 11:15 AM   #2
BYprodriver
BYprodriver's Avatar
Originally Posted by Jaak View Post
I got a set of Carera Rims with tires yesterday for a good price, sport II IIRC (10 spokes). These are as follows:
Front 235/40 ZR 18 7.5 x 50
Rear 295/35 ZR 18 10 x 65
Tires are Pirelli Corsa. My car is a 2002 S clad with 17 inch "Twist" rims.
What issues will I have? Will I have to replace the tires with 225/40 ZR 18 & 265/35 ZR 18/
Front should fit fine as is. Rear 295 will not fit Boxster & you don't want them to unless you are building a drag racer. Rear wheels need a 15mm-25mm spacer. Depending on the "look" you want & tire size you get. 265/35 is best for handling & cost. A 285/30 is the biggest you can go but makes the car understeer.
