Old 07-24-2012, 08:22 PM   #1
WhipE350
Autobahn Glanz
WhipE350's Avatar
Bentley Manual:
FRONT
Control arms to cross-member - 88ft-lb
Diagonal control arm to transverse control arm - 118ft-lb
Transverse control arm to wheel bearing - 56ft-lb
REAR
Control arm to body - 74ft-lb
Control arm to carrier - 56ft-lb
Trailing arm to control arm - 118ft-lb
Trailing arm to body - 118ft-lb
Track arm to carrier - 56ft-lb
Track arm to chassis - 75ft-lb
First thing I would check though would be the strut mount to body. They only take 24ft-lb but if loose will cause a lot of noise.
I have replaced almost all of the above recently for the fun of it so am familiar with these. The car does drive like new but it is expensive. I did find a guy on ebay though that can save you hundreds.
