					Originally Posted by brp987  Do you guarantee it to seal out rain?
 Does the ztop require work from a professional shop for fitment and installation like most aftermarket fiberglass?  Or does it really only need paint and can be installed "as is" by owner?
 Hi,  for first fitment might be better if you have or know some one with knowledge to handle tools.
 All hardware to assemble the top are including
 If a Boxster already has a hardtop, does the ztop come with everything needed to install it?
 If you already has a top you do not need more .... all are complet exept the insert/bolts for the side look. but that will be even not included if u order a OEM top at ur local dealer
 Is the glass actually glass or plastic?  Does an actual Cayman window fit?
 all glasses are real, tempered and heating  rear glass, cayman window will not fit
 Does the hatch hold open with struts like the trunk?
 the hatch you can open like ur trunk, and will hold with 2 shokes
 [/COLOR]
 Is the ztop locked when closed using the existing electrical lock in the trunk?
will locked and open  like OEM
Does it seal out wind noise as well as Porsche hard top?
might be a bit more...because includes now a hatch.... but no complains untill now
