Old 07-20-2012, 11:13 AM   #10
BestGear
If that reverse wire on the Radio is simply a ground signal then a simple little microswitch will work for that attached to the shifter mechanics.
The handbrake wire needs grounded to activate (ie, brake on), the reverse wire needs 12V + on it to activate (ie, go into reverse).
David
BestGear is offline   Reply With Quote
