Congrats on the unit, when they did the alignment did they inspect the other suspension components? There are many sources for a problem like the one you describe. Does the car drive smoothly? When you first get a Boxster the steering can feel twitchy because it's so much more precise than say a Ford truck as I switch back and fourth from. Otherwise if it's a real problem it could be a lot of different things. From worn suspension components to a bent wheel or need for balancing.
