Old 07-20-2012, 09:20 AM   #11
BestGear
What wire did you use for the reverse sensing so that the rear camera comes on automatically?
I fitted rear parking sensors at the same time the bumper was off - a well spent £15 for them - supplied painted a very close colour match too! I just ran a wire from the rear boot - but the reverse signal is available from the ECU under the (UK) passenger seat.
On my kenwood you can set it up to auto switch over to the reverse camera or ignore it.
Also, you can select the camera while traveling forward too should you wish.
See the camera and parking installs below..
David
BestGear is offline   Reply With Quote
