Old 07-18-2012, 06:45 PM   #21
feelyx
If you don't have a leak down testor you can improvise with this little trick, hook up your compressor to it and listen in the exhaust and intake for leaks.... you can also lay paper over the in/ex opening to see if any physical movement....
Just make sure you don't seal the hole through the center...
98 boxster
82 280sl parts for sale
feelyx is offline   Reply With Quote
