My best guess would be the Bendix drive on the starter. It has happened to others here on the forum. When it gets dry on lube, it makes a squealing noise when you hit the starter.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
