If you are changing the water pump it's a good time
To change the thermostat to a low temp 160 degree thermostat and also check your front engine mount for cracks or wear as its an easy swap while the water pump hoses are down..also a good time to change the coolant if it's old, also check your overflow tank in the trunk as they are prone to cracking and leaking and may as well get a new coolant cap while your at it.
