scycle2020- I think they are going to tell you to replace the tire, because it is speed rated, and if repaired, it voids the speed rating. They might say you need to replace both tires on the front end, but you should be OK with just replacing one of the two, since your mileage is probably pretty low. The good news is that it was your fronts, they cost less than the rears (smaller). I am guessing they are the Michelin's. Check Tire Rack's pricing. I think they are about $280.
