I also run my 2.5 tiptronic to 147mph without a floating feel, could it be due to tyre pression or weak suspension?
the other thing that I have heard is that the 2.5 or 3.2 litre engine are apparently the same unit with different bore/stroke, if you rework a 2.5 and change chamber/piston etc..to 3.2 parts would this work out cheaper than buying a full motor?
anyone with an idea on this?
