Thread: Lambda sensors
Old 07-15-2012, 11:58 AM   #1
Topless
Track rat
Topless's Avatar
"Aging sensor" codes usually indicate a problem directly related to the sensor, sensor wiring harness or DME issues and not a bad MAF or intake/exhaust air leak. Trace the wiring to see if has been damaged or pinched. Sometimes rodents will chew wiring as it passes through a bulkhead or firewall. There is also a circuit test I have seen in the past from DME to sensor which will help isolate the problem. A quick online search came up empty though.
After a little digging I found this most unusual error code P2096- "Post catalyst fuel trim system too lean bank 1" This is very different than "aging sensor". I would clear it and if it comes back, confirm that it is the very same error code. If it is and your sensors are new I suspect an exhaust system leak on that bank near the sensor. A small hole in the cat would do it.
I hope this helps some.
