Old 07-14-2012, 07:11 PM   #1
asexton
Coolant system question
I installed a low temp thermostat and drained a few gallons of coolant. I didn't drain the whole system cause it was done a few months back. I used the Uview 55000 and couldn't get more than 20psi due to the coolant in the system still. I used it and filled the system up. I just wanted to make sure 20psi is good enough to remove all the air from the system. I ran it and then topped off the coolant. Thanks for the advice!
Adam
asexton is offline   Reply With Quote
