Thread: 1128 & 1130
Old 07-13-2012, 06:48 PM   #10
MN 986
MN 986's Avatar
Cleaned the MAF and the car still would not start. Called a local indy shop and he said MAF or AOS would not likely cause a 'no start' situation. He said based on what I had told him, he'd look at the fuel pump relay then the fuel pump. I could not hear the fuel pump run at all, so he suggested I jump the relay to see if that powered the pump. It worked! I briefly ran the car, and it sounded perfect. I will have to order a new fuel pump relay (dealer only part, not in stock), then I hope to be back on the road.
MN 986 is offline   Reply With Quote
