Old 07-10-2012, 02:31 PM   #10
sb01box
Originally Posted by harryrcb View Post
I don't believe they make a noise you might get a slight hesitation on quick take off but most likely you will not be able to tell. the one sure way is drop the transmission and measure the movement of the flywheel plus check the condition of the clutch surface area
Thanks for your input.
Would I be able to "feel" the play if I jack up one rear tire, have the tranny in gear and try rotating the tire?
sb01box is offline   Reply With Quote
