Old 07-09-2012, 06:20 PM   #4
986_inquiry
2006 987
986_inquiry's Avatar
Originally Posted by manolo View Post
Pull up carpet in trunk, if you find coolant soaked into it you have a cracked coolant expansion tank. Very common, I went through two. You can keep topping it off but its only going to end up in the trunk if you have a cracked tank.
I have, carpet is dry.
Flashing light again today. I'm not losing coolant, just the light is flashing.
Wish I knew if this was a major problem or not.
986_inquiry is offline   Reply With Quote
