they're on there tight - 340 ft-lbs. make sure the car is on the ground when you try to break them loose...
Originally Posted by 101 Projects for Your Porsche Boxster
With the car on the ground, in gear, and the emergency brake on, remove the center hub cap (see Photo 3 of Pelican Technical Article: Tire and Wheel Sizing), and use a long breaker bar to loosen up the drive shaft flange axle nut. This nut is tightened to more than 460 Nm (340 ft-lbs): it will take quite a bit of force to loosen it up. Lift the car up again and remove the wheel once more.
