Old 07-09-2012, 08:35 AM   #2
shadrach74
Originally Posted by sb01box View Post
so I got the CV boots replaced on both sides along with water pump.
The rattle is still there. only hear it when the drive train is unloaded. Namely the car is in gear and only when there is no net power transmitted by the engine to the wheels or wheel to the engine.
any thoughts?
thanks in advance
tad
If you were getting a clicking sound from the CV Boot/joint, then there is a good chance the joint is shot... Was the joint dry? Putting a new boot with fresh grease on a worn joint is pointless. I have heard boots slap together where they've split which simply necessitates boot replacement. Did you make sure that all the components of the axle were serviceable before you installed new boots?
shadrach74 is offline   Reply With Quote
