Old 07-06-2012, 07:12 AM   #10
BYprodriver
BYprodriver's Avatar
Originally Posted by shadrach74 View Post
Could you elaborate on this a bit. I'm new to Porsches but have a lot of experience with many types of machines, cars, motorcycles etc... I'm curious about the improvements to the FI and the failure mode of the plugs and O2 sensors in the early Boxsters. Also, how is the combustion event in a water cooled motor different then the combustion event in an air cooled motor?
In 2002 Boxsters went from single hole injectors to 4 hole, O2 sensors changed to the improved Bosch LSF, also non-return fuel supply. All this led to more accurate air/fuel ratio which makes plugs last longer. I was refering to how the air-cooled engines are a completely different design from the M96 engines requiring different service procedures.
