Old 07-03-2012, 04:03 PM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by Crono0001 View Post
Thanks for the fast reply. I'll probably upgrade the clutch too while I'm down there.
Will my base transmission hold up the new engine? Do you recommend the third radiator that the S uses?
Yeah new disc with a 987 pressure plate & probably a new flywheel. Stock trans is strong enough. Since you are in AZ you will probably want to add the 3rd rad. & Box S coolant pipes.
