There are two valves in there that look similar. OEM-99660521301 is the one that fixed my whistling sound. You need to remove the wheel and the inner plastic liner to get inside there. Pretty straight forward job. The little plastic retainer things that hold the liner on can be a little hard to remove. I loosened them up with some p-blaster and had better luck with them.
Steve
2000 2.7L
