Old 06-28-2012, 12:36 AM   #13
white99c2
If it is not leaking and keeps disappearing from the expansion tank you better check the oil dip stick. If it looks milky you have intermix. Your car may have overheated so bad that the head gasket or even worse a cracked head is causing the coolant to mix with the oil. Best of luck, do not start the car any more. Get it towed to a shop fast
white99c2 is offline   Reply With Quote
