Thread: Track wear?
Old 06-26-2012, 02:10 PM   #1
BYprodriver
BYprodriver's Avatar
I would change the oil 1st to minimize engine wear, check brakes to insure proper operation & adequate pad thickness, inspect tires for unusual wear or cracks in the sidewalls from age especially near the rim edge & inflate tires 10psi over normal psi spec to minimize outer tire treadwear After a few laps adjust psi to even treadwear across the full surface & monitor brake pad wear, oil & coolant level. At this point the driver controls wear on the car.
