Old 06-23-2012, 04:35 PM   #20
husker boxster
husker boxster's Avatar
Originally Posted by LightngSVT View Post
So M96 is the better engine to have? I thought I had heard 911 guys talking about the M97 being more reliable? So the M96 can be upgraded to prevent the IMS failure where as the M97 you just have to cross your fingers and hope you have a good one?
You've answered your own question. You have to decide what "better" means for you. The M96 can have the IMS replaced for $2K. The M97 design is much better from the factory but not infallible. To change the IMS on an M97, the engine needs to be removed and the case split in half. Very expensive, so most M97 owners don't do it. The IMS failure rate is significantly less on an M97 engine, but that's based on owners reporting to forums like this one and Planet-9. No one knows the actual numbers besides Porsche.
Planet-9 has more 987 owners than here and there's way less chatter about IMS on that forum. Lots of M96 failures reported here. I own two M97 engined vehicles and while I'd like to upgrade the IMS, I'm not going to spend that kind of coin. I still sleep well at night.
Don't obsess over this issue in your search. If you buy an M96, assume another $2K on an IMS upgrade. If you purchase an M97, check the oil change intervals of the previous owner and go from there (more frequent changes are believed to be better for IMS longevity). 5-8K mi or once a yr is considered ideal.
1989 928 S4 5 spd - black
