Old 06-22-2012, 11:29 AM   #2
JFP in PA
When you installed the new pads, did you first press the caliper pistons back into the calipers, or did you just slip in the pads and let it go at that? If that is the case, the first time the brakes are applied, the pistons will reset themselves and you should be fine.
Remember to properly bed the pads in for maximum performance and life.
