Old 06-20-2012, 11:14 AM   #2
denvergold
Yes; worse yet, when it does it, it does not throw a code .......
Thanks again JFP. There's a high pitched squeal under the front right fender which is where the EVAP Canister is located. Should I start by replacing #’s 2 & 6?
Would #'s 2 or 6 also shut the car off while it's running?
http://www.renntech.org/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=8262
1 - EVAP canister purge valve
2 - EVAP canister
3 - Purge air
4 - Tank
5 - Tank pressure sensor
6 - Shutoff valve
7 - Operating purge valve
8 - To intake manifold
9 - Vacuum control valve
If so, where should I order parts?
Thanks a ton, Dean
denvergold is offline   Reply With Quote
