Old 06-19-2012, 04:44 PM   #1
99ArticSilver
Going Topless
Wiggle the water pump pulley, if there is any play it is bad,. Also rotate it and if there is any roughness its, bad.
There is a small amount of play but seems to turn just fine. I'll start with taking it off for inspection. I'm at 78K so it sounds like motor mount maybe another item to look at replacing while I'm doing this? Any other suggestions for maintenance items while I have it taken apart?
Update 10:45 PM
After removal of the water pump it was obvious it had failed. I'll be ordering a new one shortly.
Thanks to all for you help on this one!
99ArticSilver is offline   Reply With Quote
