Old 06-18-2012, 09:53 AM   #12
CoBeerToad
CoBeerToad's Avatar
I might be on the wrong page here, but maybe this might be helpful. If not call me a noob and ignore.
I don't use my clutch after getting into second gear when up shifting, or when down shifting. When preparing for a down shift, I just rev up the motor a bit and when the tension is off the shifter, I pull it into neutral. Then I rev up the motor enough and push on the shifter. When it hits it's "shift zone" it will pull the shifter into gear. Perhaps I am killing my transmission by doing this. It doesn't feel like I am. And I have never ran into any problems with any of the manual cars I have driven.
Up shifting is about the same as all manual transmissions have, what I heard referred as a "shift zone." I rev up 1st too high to shift into second without the clutch, but all the other shifts are very easy. I just run second and I'll go past the "shift zone" a bit and pull the shifter out of gear and then push it into third. When the RPMs drop a bit, it just grabs right in. (Obviously, this is not for racing).
CoBeerToad is offline   Reply With Quote
