Old 06-18-2012, 07:27 AM   #11
jaykay
jaykay's Avatar
Its just one blip. Essentially, I'm doing two things at once, blipping and shifting. As soon as I put the clutch in I blip, at the same time, I'm also moving the gearshift to downshift.
Yep if you can blip to cover the synchro and clutch engagement everytime you have got it down.....when I am on the track under pressure in heavy work zones and am worried about balky shifts I blip coming through neutral to make sure the lever moves into gear and another for the clutch...this is usually for 2nd. The revs stay up nicely but I am likely slower for it
I will start trying a longer blip to cover both a bit more in those cases
986 00S
