Old 06-15-2012, 12:02 PM   #1
hiasad
Maf change did it
Originally Posted by Andrew McD View Post
Hi, I'd much the same problem. I'd the MAF changed and leaking oil filler pipe changed. Seems as if the vacuum leak from the oil filler tube was causing all sorts of problems to performance, but I also found out a vac leak can have real problems for how the tip makes its changes. A totally different car now.
Hi there,
Thank you so much. I replaced my MAF and the car drives like a dream. It was running lean. Although the Engine would compensate for it but still it had to do a fair bit of work (21% compensation on 1 side and 30% on the other).
I appreciate your feedback and the time you took to reply me. My transmission problem is also gone and the car drives smooth.
hiasad is offline   Reply With Quote
