Old 06-14-2012, 06:45 PM   #2
BYprodriver
BYprodriver's Avatar
Originally Posted by moresquirt View Post
I was running the car hard and came into a corner hot and went to shift from 5th to 4th and missed the shift into 2nd,redlined the motor,i guess thats not good for the clutch and motor,could i have damaged anything.Also do most when shifting go thru each gear or will you skip gears if you feel your at the correct speed .thx
did you see how high the tach needle went?
You should remove your oil filter & inspect it for metal!
