Old 06-10-2012, 05:46 PM   #3
Steve Tinker
Steve Tinker's Avatar
If a mist "blew out" then it sounds like it was under pressure - I would check your oil and coolant levels after its cooled down a while.
Make sure there is no intermix of coolant in oil or oil in coolant.
If its just the coolant level down, you must identify the leak before driving it again - it could be something simple like a hose clamp, a split hose or the water pump. The rads are at the front so that kind of isolates them from the conundrum.....
Keep us informed of the outcome.
2001 MV Agusta F4.
