Old 06-10-2012, 09:46 AM   #1
doragman
doragman's Avatar
Finally got around to replacing the clutch switch. My intermittent starting issue never left me stranded, but decided to replace the switch (about $30) figuring it would go out completely sooner or later.
Easy to replace - one screw (went easier when I figured out the nut was fixed, and all you needed was a stubby Phillips head screw driver)...the 2 wires are clip on ...total job time is 5 minutes.....can't screw it up .......the hardest part is laying on your back under the steering column to access.
Completely solved my Intermittent starting problem ...wish I would have done it sooner! ...
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
