Old 06-09-2012, 09:29 PM   #2
bar10dah
bar10dah's Avatar
I've seen posts where folks discovered their CEL bulb was missing. Seriously! Appeared the previous owner would remove it to hide the fact that the CEL was on. Yeah, I know, shady. If I remember right, a missing bulb produces a DTC. I wonder if a burned out bulb will also produce a DTC? You should check for codes to be sure.
Also, many threads on this forum about the horn honking over bumps. Can't remember the exact nature of the problem, but remember a few o-rings fixed the problem. Or even a replacement of the airbag or steering wheel mount, I think? I really can't recall right now. Give the ole' search function a try and you'll find your answers.
bar10dah is offline   Reply With Quote
