Old 06-08-2012, 02:52 PM   #12
Jittsl
SPB racer
With PCA Z8, you can run top down with 5pt and arm restraints as long as you pass broomstick. Most guys run top up.
When I was running events for NER I always presumed that the required arm restraints automatically meant harnesses which (for NER anyway) meant you had to have race seats. Most people found a way to get the setup low enough to pass the broomstick. So all was good.
Recently however, on this website, I discovered that there is such a thing as arm restraints for stock three point belts. They won't be so easy to make work.
Not sure that the softop is really going to help if you are unfortunate enough to roll your Boxster.
Laurie
Jittsl is offline   Reply With Quote
