Old 06-08-2012, 11:18 AM   #11
Topless
Track rat
Topless's Avatar
Originally Posted by Jittsl View Post
Odd to me that the loop bar is not considered capable of doing the job. It is actually constructed like the veritable brick ****************house and mounts to four solid pieces of boxed chassis.
Laurie
I think the stock roll hoops are plenty strong enough. The problem is with stock seats and a helmet, most drivers taller than 5'6" will have trouble passing a broomstick test. Worse case scenario you roll the car and support the weight of it with your neck. I added racing seats bolted to the floor and a BK roll bar extension so now I am 3" below the broomstick.
With PCA Z8, you can run top down with 5pt and arm restraints as long as you pass broomstick. Most guys run top up.
