Old 06-07-2012, 08:05 AM   #16
seningen
seningen's Avatar
Originally Posted by Tim1137 View Post
Im curious why people say its going to cost so much? How much is a used engine? 2-3k?
Rebuilding your current engine, how can that POSSIBLY cost upwards of 15k? Can someone break down the price a bit?
All depends on what you decide to do and what damage was done.
Goto Pelican and add up the parts you are going to need.
Assume bent valves, IMSR, probably have to source a used IMS Tube.
head gasket, engine seals kit, fluids.
Then you have a lot of WIAIT costs.
It adds up quick. But you should be able to do it for 7-10K depending on labor and WIAIT costs -- however upon
teardown -- you might find the damage was catastrophic.
A 2.5K engine might be fine -- or it might be a nightmare.
Check the leak down, IMSR, and replace the WP at a minimum.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is online now   Reply With Quote
