			If there is no CEL, you don't have an air leak.  The WIFI OBD2 is just a coincidence :P
 However;  It sounds to me like a MAF Sensor.  These seem to fail quite a bit in boxsters, especially the pre-2000 models.
 There are quite a few things it could be.  But if the idle seems to hunt as you describe and occasionally find it's "proper" idle, then i would mostly likely assume it was a MAF sensor;  especially without previous knowledge of the car.
 Best of Luck!
 ~Brad
