Old 06-06-2012, 02:01 PM   #3
Johnny Danger
Johnny Danger's Avatar
Originally Posted by coolbreeze551 View Post
Thanks JD. What spacers would you recommend on the front to change the "stance" to be a little more sexy? Also what size bolts am I looking for for these spacers? Thanks
Since the fronts are only 8 inches wide, depending on what size tire you'll be using in terms of width, I'd recommend bringing the front offset down to around +40 (i.e. 10mm spacers) . As far as lug bolt length is concerned, simply add the increase in spacer width to the oem bolt which has a shaft of 28 mm's . For example, 28mm + 10mm spacer = 38mm bolt, or thereabouts . Be careful, however, not to use lug bolts that are too long in the rear ! If they're too long, they'll protrude into the e-brake assembly and cause a mess .
