Old 06-06-2012, 01:48 PM   #2
coolbreeze551
The fronts will fit without the need for spacers, but the "stance" probably won't be to your liking . The rears, however, will require 20mm spacers (IMO +50 is not enough offset) in order to give you the clearance that you need and 'look" you want .
Thanks JD. What spacers would you recommend on the front to change the "stance" to be a little more sexy? Also what size bolts am I looking for for these spacers? Thanks
