Uview cooling system bleed?
Question, I just got a Uview tool. Can I use it to bled the existing cooling system to remove any bubbles?
Also have a 2000 S with 39k miles. Water pump seems fine, however I have new water pump and low temp thermostat ready to go. Should I just change out based on age alone? Also, should I do the expansion tank at the same time on general principles?
