Old 06-04-2012, 02:15 PM   #4
JFP in PA
Originally Posted by luke1834 View Post
The refrigerant was removed from the system by the indp. shop when they diagnosed the problem. This was how they "locked out" the compressor so I could drive it without worrying about the issue recurring.
My "plan" is to have the same indp. shop fill the system once I changed the compressor and drier. Is this unreasonable given the circumstances?
I definitely qualify as a part swapper, including the coolant tank and AOS as well as many other jobs on other vehicles...though I am also familiar with a saying regarding mice, men and plans...
As best I can remember, the AC worked great before the issue started. It was January, though I do not recall any noticable noises or symptoms of problems with the AC. The shop said they pressure tested the system and found no leaks.
That being the case, I do not see why they vented the system, they could have totally stopped it by simply pulling a fuse that would have cut power to the compressor’s drive clutch, allowing it to freewheel.
I am not at all comfortable with scraping a functioning system. I’d have someone more knowledgeable look at it first.
