Old 06-02-2012, 07:25 PM   #4
rdc8118
Originally Posted by copsahl View Post
You can get a 76 mm filter wrench (size B) at Autozone, etc for about $5. Fits a 3/8" rachet.
For the Canadians you can get it (76mm - 14 Flutes) from Carquest for around $10.00. Some of the Mazda's and Ford's use the same size wrench. To avoid the hassles of duties and customs brokerage charges, I've bought parts from autopartsway.ca, pcarspecialist.ca and the dealer. Some times the dealer has surprised me and had the best price on a part. so I call them first for a quote before ordering online.
For the oil I just use Mobil 0w40. I'm not saying it's the best - don't want to get sucked into the oil wars. It's a good idea to order an extra drain plug. It's easy to strip the hex socket if the wrench is not fully seated. I keep an extra one hand just in case. I also cut apart my oil filter and run a high power magnet over it looking for bits of steel. Hopefully this will give me a heads up in case my IMS bearing is grinding away
rdc8118 is offline   Reply With Quote
