Old 05-29-2012, 09:29 PM   #13
Johnny Danger
Johnny Danger's Avatar
Originally Posted by bar10dah View Post
Thanks for the reply, JD.
The fronts only come in 54mm.
Your suggestion of lowering the offset by 10 mm, is that to increase the clearance to the strut housing? Is that the primary concern?
By adding a 10mm spacer you will create more inner clearance (i.e. from the strut), and the wheel will be moved further out toward the fender .
