If it is so damned good, why does it tear around the center opening? I have never seen a Wix do that. And it does not address the glue line delamination failures where the media is bonded to the end cap, which is an even more common failure point.
not sure if this is possible for you, but do you think you could ballpark the % of filters you've removed vs the number that had these issues?
