Old 05-23-2012, 10:50 AM   #1
Perfectlap
Perfectlap's Avatar
ACCUSUMP - Discuss please (oil starvation)
sounds compelling..
Preventing oil starvation on the track in your Boxster, Cayman, or 911 model Porsche.
For those people wanting protection that is streamline and transparent, adding a 2 QT Deep Sump that is fully baffled to prevent sloshing of oil, in addition to the two extra quarts of oil, is a step in the right direction, as mentioned previously. Adding Dual Tandem Scavenge Pumps to the cylinder heads adds one additional scavenge stage to each head, allowing the engine to suck oil that would otherwise be trapped in the cylinder head under high G-forces, improving oil pressure in turns under high G-forces by at least 15-20 psi, based on data reported by others using the factory pumps.
Completed installation on one cylinder head bank (looks pretty much the same on the other side). Note we supply non-descript black hose and fittings to make the installation look as factory as possible
BORN: March 2000 - FINLAND
